1992 Toyota 4Runner Engine Code 42 (VSS Circuit)
I have a code after driving for about five minutes and it js code 42 which is vss circuit and im trying to figure out what would cause it. It is manual swapped abd everything is plugged in... not to sure on what it could be. Any help would be appreciated!
Code 42 is "Open or short in vehicle speed sensor circuit." I'm not sure what you mean by "manual swapped," but unless you have the electronic speedometer the vehicle speed sensor is in the combination meter (instrument panel). I suppose you could jack up a rear wheel, probe the SPD pin at the ECU, and watch for changes when a rear wheel is rotated.
My EWD shows SPD at connector E4, pin 9
Does that help?
Does that help?
