1992 Pickup Washer Fluid Tank Cap
Old 06-24-2024, 08:42 AM
Green's Avatar
After a few years of fixing with hot glue, my washer fluid cap finally disintegrated to a point of no repair. Now I need a replacement.
I've tried Amazon and had a couple botched orders that they said would fit but do not. I tried searching the local parts store to find that "universal" caps are not universal.
Anyone know of a part number or replacement from another vehicle that will work? The outer dimension of the tank fill hole is about 2.3" with about 0.13 lip depth and about 2.1 neck diameter.
Edit: Truck is 4X4, X-Cab, with 3VZE and manual transmission.
Old 06-24-2024, 09:12 AM
prcnctoyo's Avatar
Check out this link for online parts catalog. I selected a VZN100. You can select the frame code and char to match yours.
https://www.japan-parts.eu/toyota/us...d-washer#85332
Click on the 5 digit # for the cap, 85332. A list of 10 digit part #s should pop up. The first two are still available through toyota.
Discombobulated's Avatar
https://www.ebay.com/itm/18522539226...mis&media=COPY
Quite a few on eBay as well.
Old 06-24-2024, 10:27 AM
Green's Avatar
Thank you both. I think one of those will work.
Old 06-24-2024, 11:27 AM
prcnctoyo's Avatar
The Toyota ones are less than $6 if you order online and pick up at a local parts dept vs $20 for the ebay one.
1stgenboy
06-25-2021 04:10 PM
Jooosshua
05-21-2020 06:13 PM
FourRunner89
06-12-2013 06:03 PM
BT17R
12-10-2010 12:39 PM
petros
07-29-2006 09:27 PM
Quick Reply: 1992 Pickup Washer Fluid Tank Cap
