1991 3.0 Head gasket Repair advice
Old 11-19-2010, 02:39 PM
  #221
xxxtreme22r's Avatar
ok, now that you got it pointing at #1 fire it up, if it does anything funny, spin the crank back to TDC and if it's pointing at #1 again point it at #4 instead. If it's pointing at #4 after putting at tdc the second time take it out and point it @ #1. And try again.
Old 11-19-2010, 02:41 PM
  #222
RedYota91's Avatar
Agreed. SHOOOOOOT! Im soooo psyched that I think I found the problem and Im sitting here putting the timing cover on... The alternator belt, the fan...shroud...Grrrr! Just wanna turn the key!
Old 11-19-2010, 02:46 PM
  #223
MudHippy's Avatar
Yeah, so next time read the instructions before putting the distributor in the hole. Line it up with the marks on the gear and shaft housing, then carefully put it in without moving it using the mark on the top(not the bottom where the other two marks are)to line it up with the ignition timing mark on the head. That puts it facing #1.
Page IG-25.
http://personal.utulsa.edu/~nathan-b...13distribu.pdf
Old 11-19-2010, 02:51 PM
  #224
RedYota91's Avatar
Next time? God willing, there wont be a next time!
Old 11-19-2010, 02:57 PM
  #225
MudHippy's Avatar
Well, you never know.
And don't feel too bad, alot of guys can't get it right even with the instructions.
It never seemed that confusing to me. I'm one of the rare ones who's never managed to put the thing in the wrong way. I've done it atleast half a dozen times now myself without issues.
Old 11-19-2010, 03:25 PM
  #226
RedYota91's Avatar
It started!!!
Old 11-19-2010, 03:26 PM
  #227
hehe, now just get a timing light on it to fine tune the timing.
Old 11-19-2010, 03:31 PM
  #228
RedYota91's Avatar
So... Uh... With all new gaskets and the fact that its 40 degrees out.. Would it be normal for the truck to smoke a little... :X
Old 11-19-2010, 03:35 PM
  #229
yup. normal for a little while. especially after a tear down.
Old 11-19-2010, 03:45 PM
  #230
RedYota91's Avatar
Excellent!! Plus, now that I think about it, I put oil on the pistons, and spilled a little while filling it up :/
Onto other things.. I am not going to leave it running right now. By myself, I could not swing and tighten the alternator so the belt is squeaking like a mofo! I'll set that aside for another day. Im just so excited that its running!!!
Finally, I just wanted to say thanks to all of you. Without your help, pointers and motivation, I have no doubt that this project wouldnt have been completed. Simply put, I could not have done it without all of you. Thank you so so so so much! If you were all here, I'd be taking you all out for a beer or three..
Old 11-19-2010, 03:49 PM
  #231
just don't forget to get a timing light on it.
Old 11-19-2010, 03:52 PM
  #232
RedYota91's Avatar
Hahaha! No problem. My little brother's friend has one. Do you just hook it up to the number 1 plug cable, shine it at the crank and spin the distributor? I think thats what I read about a different car.. Hmm, I should probably search, huh?
Old 11-19-2010, 03:59 PM
  #233
yup, that would be right. but when you put the light on the #1 plug wire, put it as close to the plug as possible not by the dizzy. 22re's don't have that problem, but since the 3vze the #1 plug is clear across the engine bay. also don't forget the battery connections for the timing light as well. otherwise it wont light up lol.
Good thing I asked you to take that dizzy cap off and not assume you had it on there properly huh?
Old 11-19-2010, 04:09 PM
  #234
RedYota91's Avatar
Hahahaha! Yup! Its never safe to assume I did EVERYTHING right
Old 11-19-2010, 04:13 PM
  #235
92 TOY's Avatar
honey i'm home.
holy crap it's running!!!!!
wahooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooo!!!!!!!!
psyched for ya man.........and only a little help.
very good......ya did it. now it's gonna be my turn soon.
Old 11-19-2010, 04:17 PM
  #236
I'm gonna have to conveniently forget how to get to Jerry's house when that time comes haha.
Old 11-19-2010, 04:22 PM
  #237
92 TOY's Avatar
HEY!!! Not nice.
hehehehehe
might be a reality sooner than I thought.
Old 11-19-2010, 05:01 PM
  #238
Wrenchinjoe's Avatar
Congratulations Red
Old 11-20-2010, 04:17 PM
  #239
RedYota91's Avatar
Thanks! Im still psyched that its actually running! We've got a few more things to do before I'll allow him to take it out on the road.
-Flush the coolant. After scraping all the FIPG that was throughout the engine, Im sure some fell into the passages.
-Oil change. After having to do 4 helicoils, Im paranoid that some metal flakes got in by the cams and I wanna do an oil change to make sure its cleaned out before we rev it up.
-Tighten the alternator belt. After getting back in there and putting the engine at TDC, I had to try and muscle the alternator out while tightening it, and it was a fail. I started the 4Runner and it was squeeeeeaaaaallling like a mofo! Kinda loud inside of a garage!
-Get the timing light and fine tune it.
I think thats it! It is going to need brakes sooner than later too, but Im just stoaked to get it back out on the road!! Your turn 92 TOY!
Old 11-20-2010, 04:26 PM
  #240
92 TOY's Avatar
that psyched part does not go away. i still have mine 6 months later. it's quite the accomplishment.
congrats again man.
Quick Reply: 1991 3.0 Head gasket Repair advice
