1990 toyota pickup 5" IFS eliminator
#81
well i managed to get the truck on the springs, frame basically fully cleaned, brakes all together, tires on, and motor mounts welded. oh and the crossmember all welded up. but i hit a huge snag, when pulling my pitman arm off apparently the puller i used was for a tie rod end not a pitman arm but it was the only one that fit. so the first few threads on my steering box are messed up bad!!
#84
the guy in the background is the only person who showed up to help me and he was only able to stay for about 2 or 3 hours. so i did everything by myself... it was horrible! ahaha
#86
Awesome build! Love the finish on the axle. Quick question, how did the 4 inch IFS lift work for you? Id love to put my truck that high. Any suggestions for kits?
Good luck with the truck! Looks like you know what your doing.
Yotanewb'
Yotanewb'
#88
other news, my truck has leveled out except for the rear needing to be lifted to match and the passanger side rear sags which it always has. i have a die to fix the screwed up steering box threads coming in wednesday and then its off to alignment and shock hoops and steering stabilizer... sounds like a long list but its a bunch of small things so it shouldnt be too bad.
#89
also, if n e one could tell me how long the perches will need to be to make my 63" chevy springs almost match my 5inch kit up front that would be great because they are very much needed now!
#90
another thing, i had a but load of pictures of the truck sitting in the parking lot and other things but my phone fell out of my pocket while i was on my way home on my motorcycle so who knows where it went.
#93
the little truck on the side of it is a 1983 toyota trailblazer that is going to be the low crawler. and the chevy that i have already posted pictures of is going to be well, rediculous haha
#96
if you wanna look at allllll of the pictures here you guys go!
http://s246.photobucket.com/albums/g...9/1990%20yota/
#100
at the moment i just hve some large block in the rear. but i am doing 63inch chevys later on, i actualy have them in the bed of the truck
i finally finished it yesterday and it isnt aligned. my relay rod seams to long. but i drove it down the road and it seamed fine.
