1990-95 4RUNNER service manual link
Am I missing something...looking for anything on the 22RE...preferably close to a 92. Can someone point me in the right direction? New here, so please excuse my ignorance
Under Toyota Workshop & Repair Manuals, which engine manual is for my motor...or is there one? Thanks
1992 Yota 4wd...22RE
I may be wrong, but I believe the 22RE should be covered in the Hilux Pickup manual? I wouldn't take that as gospel, however. Someone better placed than I on the subject will clarify, hopefully.
#26
Just popping up a quickie to mention that I've added a torrent setup to the site now too. It's a new setup, so I may have an odd quirk or two to sort out yet, but it's up and running and should, eventually, make the file availability better than it was via ftp alone. It's the little green icon for the torrent file:
#27
#28
Argh, I'm such a Newb!
I hate to have to ask this but I can't figure out which service manual I need.
I've got a 92 4runner with a 3VZ-E engined four-wheel drive model with an automatic transmission.
I appreciate your help and patience.
#29
You want this manual: 4-Runner/Hilux Repair Manual - 1990-1995
#30
#31
89-93 3.0L distributor wires
sorry new at posting--have 93 w halfway installed 3.0 but has 89' distributor w connector cut-off. do wires go color to color (wh-wh,rd-rd,gr-gr,bl-bl,etc.) i hooked them up this way engine runs real rough w code 12(no"ne and g") & 41(tps). i know 12 is distr. related and "ne" is white wire "g" is green wire. does this mean they are backwards? any diagrams or inside 93 distr. pics? bought cheap w salvage motor in it unfinished -no 3.4 yet
#34
Say.........I haven't been around much, but I check in from time to time and noticed the other sticky (I forget the author) with manual links is gone. I had posted some links myself and wonder where they got off to and why.????? I mean, no big deal......I could post them again. But, I'm just curious.
#39
so for those of you who didn't get this to open:
google bittorrent, download this program,
the file should auto open with bittorrent
also download winrar
then once it's downloaded, right click on it and choose "open containing folder"
when you double click it to open,
it should auto-open with winrar
winrar will say "this is a trial version you need to pay for it" or something like that after the 30 day trial,
just click close on that box and it will run just fine, I've had it for more than 3 years past the 30 day trial
the FSM will open in your default browser,
it is not an online document however so you don't need to connect to the internet to open it.
now you have FSM awesomeness and you can bittorrent tons of crap
