1990 3vze has no 02 sensor
Old 10-07-2015 | 05:37 AM
Gone Fission's Avatar
Aftermarket exhaust has no 02 port, the pigtail and sensor are missing. Will get this fixed when vehicle is road worthy but until then how well can I expect this engine to run without sensor? Only has one code 21 - heated oxygen sensor signal.
Old 10-07-2015 | 06:51 AM
nordicwargod's Avatar
The computer gets no signal from the o2 sensor it will run in default mode which is rich.
Short term not anything real bad [short trip to the store], long term you will get bad mileage, engine gets all carbon'd up, cat runs real hot and fails, exhaust will be hotter than normal [glowing manifolds], head gasket failures, etc. Lots of bad things long term are possible.
That little sensor does more than most people think.
Old 10-07-2015 | 11:23 AM
Good to know.
Can I still set timing?
Old 10-07-2015 | 04:43 PM
Originally Posted by Gone Fission
Good to know.
Lack of an o2 sensor should not affect the timing or vice versa. Someone else with more knowledge of the v6 computer may chime in.
In default mode the timing "may" be affected but I just don't know.
Keith Lloyd
10-08-2015 05:35 PM
jdt79
10-07-2015 10:56 AM
jakey poo
10-05-2015 08:38 AM
rushw
10-03-2015 12:37 PM
Quick Reply: 1990 3vze has no 02 sensor
