I cannot figure out for the life of me why I cannot post a wanted add on this forum?? I need a compressor manifold for my Toyota Denso compressor! Help!
That's just it, I don't know which one I need exactly. It's for my 89 22RE. I believe the hose ends are the "peanut" style. My truck did not come with AC and I installed an aftermarket system 2017. I have a nice new reman Denso compressor and the correct clutch. So not having and original compressor I do not have the manifold. As you know they do not come with the compressors.
I've been looking for them on my 86 22re for the Denso 10P-13C compressor. I have not found any that look like the OEM ones. I saw a lot of manifolds on various webpages. Sadly, none looked like mine. Mine looks to be a separate small manifold for each of the Low and High sides. I imagine your lines run in from the side as well since s it's a 22RE. Happy hunting.
This is from 88 22re compressor. The low side does not have room for a straight barrel adapter. Instead I have to use a 90 degree elbow that leaks after a year or two.
That low side manifold looks weird with the schader valve in the rear and the hose connection in the front. The high pressure manifold looks just like my 86.
