102'' Military Style Anetnna & Tie Down.
#25
That was a result of a charged ionosphere reflecting your signals back to earth. In CB language, this is known as skip and though, maybe fun, it can render local communications down to zilch. Especially when the sunspot activity is at its greatest. I beleive we are back on the upswing of the 11 year sunspot cycle. During peak, radios are worthless for local communications. In HAM language, this is called skywave propogation. VHF signals are not reflected, but cut through the ionosphere. There is a rare instance where VHF will "skip" and its called tropospheric ducting and ultra rare. These radios (2 meter is the HAM work horse band AKA VHF) use FM also, so they are quiet in your rig, even if you have a noisy ignition system. There is also a VHF high band, or 220 MHZ (1.2 meters) and the UHF low band, 440 HMZ. There is others, ie 900 Mhz, which is geting into the SHF or super high frequency, and then the SHF band of 1.2 Ghz (1200 Mhz)
Its a lot of fun. Check out some radios at http://www.aesham.com/ or try http://www.hamradio.com/
OK, sorry if I have gotten off topic here. Back on course! Maybe a HAM radio thread would be in order?
#26
I am currently running a wilson 2000 trucker mounted to the bike rack
I am thinking of mounting a 102''whip on the rear bumper or a door jamb mount and tying it down lmilitary style to the roof rack when not in use.
Does any one have any pictures of what this might look like or any experience with how it works?
What about ideas to tie it down?
Never did like spotters...pointing their fingers left and right....pulling down on the corners....stacking rocks making a bridge My antenna says "stay away!"
Got the 102" stainless steel whip mounted...Got the whip from Radio Shack for $25.....mounted it central on the rig. Glad I have the tool box
102" whips have no adjustment because they are 1/4 wave long....very broadband. If there is an SWR issue then either something is seriously wrong with the mounting process or somebody's about 100 channels off frequency
A little history....Started out CBing it in 1973....did a couple months in 1974 of "pirate" hamming on 40 meters Novice band(morse) with fake call of WN7BDS....1975 got a real Novice license of WN7ELC....1975 upgraded to General WA2EAS....1976 upgraded to Advanced. Did some 'hammy' things like build my own rotational 2 element 20meter directional quad antenna with wood and wire...built a Heathkit 101....only shocked myself once on 280 vdc in the process....mostly enjoyed the "QRP" operation on 40 meters cw....that would be morse code on 1/2 watt power late at night on 7125 kHz.
In any event, CB is still the mode for 4x4 groups on the trail. If you've ever been to Easter Jeep Safari with out one then you know how "left out" you feel on the trail.
I also see lotsa potential for GMRS/FRS walkies. I just ordered myself a pair of Motorola T9550 T9550XLR 2 Way Radio 25 MILE Walkie Talkies
http://cgi.ebay.com/ws/eBayISAPI.dll...m=320171694763
Tough finding a good spot to mount the semi-bulky CB I chose but I found a workable spot
#27
Guess I beat you to the posting of the pics, 91muddog!
#28
just got over splaning it a few pages prior.... dont matter the lenth the base is the transmit and the top of the antanna is your reception..... hence, the higher u mount it the better u get out!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
#29
splaned it a few pages prior.....dont matter the lenth.. the higher u mount it the better u transmit.. cuz the base is the transmit part of the antanna and the top is the reception.... and must do an swr check every time it gets hit hard......................
#32
102" whip in a RR corner would produce a strong signal out the LF, but weak out the RR. Ideally, a antenna mounted centrally is the best. A 102" whip is a 1/4 wave, but for best distance, a 5/8 wave is the ticket. But you would bneed to increase ant length by about 50" and that would be done by adding a coil on the top in the form of wire wrapping. Look into an NMO type mount and tghen an NMO-27 antenna. Small, compact and unscrews easily to put away. Oh, I'm also a license HAM operator! :;D:
#33
Although HAM operators and CB people don't always get along, I would totally agree. I myself, a CB operator, use a Wilson 5000 magmount on my roof (centrally located...). I never had any problems, ever. There are a few different antenna mounts out there. I will try to post some pics afterwards.
#34
i had a piece of flat metal with a 'G' shape knotch cut in it. it was clamped, like a KC lite bar to my rain gutter. the the cut was just enuff to slide the whip in to, and the ball kept it from coming out.
but if you go wheelin, let it out cause a brach will break the whip or the mount, or both
#36
CB Stuff....
Hmm, glad i found this thread...not to take away from your discussions about eyeloss..but i have a few questions bout this stuff....
I got a cb radio, with a roof mounted wilson 1000 base mount antenna....(it can unscrew when not in use and the mount gets covered with a plastic cap)
it wasnt wired up...just the antenna and cable were wired in...so i wired it in tonight....got power etc. but no channel had any chatter etc. does it need an external speaker?
anyway, my other question is this...the Wilson 1000 has a small metal spike on the top with 2 setscrews in it...i read up online and i guess its suposed to have a 62.5" steel whip attached.....
mine doesnt...now, i only use it on the trails...so i dont need much in the way of range...will it still work??
Sorry for the hijack....
Thanks
Paul
Thanks
Paul
#38
4Runner HF Antenna Mounting?
I am looking for mounting options for a 7-54 MHz HF antenna on a 08 4Runner.
Using a ICOM 706 MKIIg with AH-4 antenna tuner. Also looking for suggestions on engine related noise reduction steps. Thanks!
#39
#40
here are some other CB antenna mounts. there are also a couple of pictures of alternator mounts for those of you that wanna get to be a BIG MAN on the radio. if you decide on putting in a LINEAR AMPLIFIER, which is ILLEGAL, you may need to put in a high amp alternator. but if you are power hungry... you may have to option for more than one of those alternators. by the way, in those pictures of the multi alternator mountings, they are all 200 amp alternators. thats right, 200 amps each. some people don't believe it when I tell them that.
