Where to put grey sealer on timing cover?
Old 03-31-2013, 10:31 PM
pcmentor's Avatar
Should I put grey sealer on the block side of TC gasket and the TC side? How about the water pump gasket? Both sides? I tried searching here but did not find this info.
Old 03-31-2013, 10:41 PM
Philbert's Avatar
22re?
BOTH for both gaskets
Old 03-31-2013, 10:45 PM
Co_94_PU's Avatar
Book says to dry fit them. But personally I put a dab at each bolt hole to keep a gasket from sliding around too much. Definately put some on the flange and upper section of the single bolt from the head to the TC under the distributor cam, that puddle is just a leak waiting to happen.
Old 03-31-2013, 11:09 PM
pcmentor's Avatar
Yes 22re, sorry. Thanks
Old 04-01-2013, 05:16 AM
Philbert's Avatar
Agree on this too. What I do is take a big glob of Toyota form in place gasket (FIPG - get it at the dealer - the black kind, not red [that's for gear oil stuff like trannies]) and smear it on the end of the timing cover bolt that installs under the cam gear, then install the bolt right away - this kind of gums up that hole and helps stave off any leaks from the puddle that forms there. This is the "hidden bolt" everyone talks about.
Old 04-21-2013, 10:46 AM
WeenieHutJr.'s Avatar
Copper spray a gasket. Much cleaner than rtv if you
Must use something.
Old 04-21-2013, 10:51 AM
85TurboRunner's Avatar
Hmm of all the times I've replaced heads and timing covers I have never done that and I usually end up with a leak or seep right there.
Learn something new every day.
Ichneumon
09-27-2015 04:21 PM
puddlepirate
06-30-2015 05:08 PM
Badger62811
06-26-2015 09:26 PM
94 First Responder
06-06-2002 02:19 PM
Quick Reply: Where to put grey sealer on timing cover?
