Where to drill for wiring 85 dlx pickup
I'm not quite sure where to run the wiring for a light bar there are no fire walls that I can find easy access to. This is a 22r. I can wire everything fine I just need to know where to run the wires into the cab.
Pics are a big help
Pics are a big help
A 22r and you can't find a spot on the fire wall? There should be a bundle of wires going in by the brake booster, steering shaft grommet, or you could drill a new hole in the fire wall.
