What is this brake part?
I see two brake lines from the front coming into this thing and one coming out to the rear. There is one hard line cut off sitting there from it. What does this thing do?
Why doesn't the lines from the front just connect to the rear and be done with it and why are there two lines to it? Shouldn't there only be one line from front to the rear?
I'll have to look in my book for more info about it and see if i need to fix a line that's capped and the other nozzle that's open possibly and make sure it's A-OK. Wonder if a bad one of these would help cause not so good brakes after I put new master cylinder on and bled them despite a small rear axle leak of seals that could be getting on the shoes and ruining it a little.
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
