vented rotor question
i am doing the vented rotor swap and have run into the issue with the wheel studs. i bought the ones recommended on the pirate4x4 and they are not going in. i have a small 12 ton press and it wouldn't even get them in all the way. what are you guys with this swap running for studs?
thanks
thanks
the stock 79-83 studs .. which , i'm not positive .... but i'm sure there the same as the 84-88's ?
EDIT:
actually , arnt the landcruser the same as well ?
EDIT:
well the land cruiser studs have a knurling that is a bit further down to compensate for the rotor thickness. this is from what i gathered looking at them side by side. my new studs are about .015 thicker, which is apparently too much. i am having one hell of a time getting these in. it shouldn't be this hard, i guess i have to borrow a car and order oem. i'm pretty fed up with working on this truck.
well i took them to napa and their press had no issue with them, the guy said they are going in tighter then normal. only charged me 5 bucks too. i gave him 10, and if i had a 20 i would have happily gave it to him. so my pos 12ton press is going back for a 20ton. oh well, on to the reassembly.
thanks
thanks
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
TJWilly
07-31-2015 02:05 PM
britishdudes2dr
07-25-2015 06:47 AM
