v6 3.0 swap
v6 3.0 swap
Im looking for information on swapping my 89 4x2 3.0 5 speed truck to a 22re. What would I need, can I use my tranny with a 22re bell housing, and what about wiring and clutch slave and so forth. The only reason I want to do this to this truck is that the body is in good shape with 230,000 miles. thanks if anyone can help
i can help somewhat, you well need an r151 bellhousing (hard to find, better get a 22r-re tranny and t-case) the engine wiring harness,ecu and maybe some of the harness under the dash (im not sure on this)you should be ok with the 3.0 clutch master and slave.
