tranny stick
tranny stick
my tranny shift stick has a hell of alot of play. doesnt stay in the correct position and will rotate around when i try to shift. any ideas on how i can fix this problem?
Hey I tried one of these Marlin Crawler shifter sheets and it helped tons!
http://www.marlincrawler.com/htm/tra...rans_parts.htm
I believe you pop it in neutral, press down, and rotate the stick a quarter turn. Don't know if its left or right, but its just a big washer thig holding it down and you have to rotate it for it to lift out.
Just don't let stuff fall into the tranny when you get it out.
not to hard this should give you a idea http://www.4x4wire.com/toyota/reviews/quick_shifter/
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
hiluxinargentina
09-30-2015 05:51 PM
