Timing issue
Old 08-18-2015 | 09:52 AM
insadj05's Avatar
Timing issue
85 Toyota Pickup 22R engine. New carb, (Weber) fuel filter, fuel pump.
Starts and idles but when raising rpm will back fire. Also cannot get the timing to 0 degrees. it is about 3/8" to 1/2" the the right of 0 and the dizzy is adjusted as far as it will go in the adjusting slot!!!!
Thanks to all for your help.
Old 08-23-2015 | 09:11 PM
yoterr's Avatar
So when you rotate the crank around you can't line the mark on the pully to the 0 mark? And did you do anything new besides changing carb?
bigjstang
08-25-2021 12:41 AM
Regency
20
01-03-2020 07:43 PM
coryc85
09-09-2015 06:24 AM
msane99
07-11-2015 08:08 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Timing issue
