timing chain
timing chain
What would cause a timing chain tensioner not to work, I have taken the cover off and everything is in place but when I start the engine the chain is hitting the cover. It`s a 1981 22R
Chain hitting the cover...?
If its hitting the inside of the cover then you have damaged/missing timing chain guides(dampers).
The chain tensioner is an oil assisted spring tensioner.
Low oil pressure can cause timing chain tensioner to be inoperable/faulty.
Low engine oil level.
Incorrect engine oil weight.
Oil gallery passage blockage to timing chain tensioner.
Failed oil pump.
Incorrect timing chain tensioner.
Timing chain worn beyond service life.
Internal engine damage.
Failed oil pump.
09-04-2015 09:27 AM
