swapping an 84 22R to an 85 22RE
Whats up dudes. I have a 1985 22RE that got sideswiped and found a 1984 22R with a knocking motor. since i have complete cars what would i need to swap over the fuelie to the 1984?
I remember researching a while back that i would need the efi dash or maybe just the efi gauges.
both are 5spd but the efi is hooked to a 2wd tranny and the 84 is 4wd. are the carb/efi flywheels the same?
Swap the entire fuel system tank to engine put your wiring & dash cluster from your 85 into the 84. Would it be easier to just cab and bed swap the 84 stuff on to the 85? Then you probably just looking at pulling the wiring, ecu
& dash cluster from the 85 cab and installing it in to the 84 cab.
The following users liked this post:
old87yota (01-11-2020)
Yeah this.. All your intact EFI stuff onto the intact carb body, then repair any of the efi stuff you need to like damaged wires.. Essentially follow Terry's EFI to carb swap in the other direction.
iraqsucks
07-30-2012 05:17 PM
