Sudden Hard Shifting?
Hi all, happy new year to you!
Wondering if I could get some advice on this. Just yesterday it began getting very hard to shift my 2wd 85 (w55). There is quite a bit of resistance moving the lever into gear especially 1st and 2nd. It is somewhat intermittent, occasionally goes in just fine. In neutral, if I move the lever all the way to the right it won’t spring back to center on its own.
I don’t see any leaks. Gear oil was changed a few weeks ago (80-90 conventional) and replaced the bushing that sits at the bottom of the lever at the same time. No problems until now.
Any ideas on what might be going on or things to check?
Cheers
Cheers
Any chance it's just because it got cold out? Just a guess as I don't know your location. Or shifter boot or carpet interfering somehow?? You changed the shifter bushing, does your trans also have the plastic cap/tip as well? Good luck and Happy New Year. Post up whatever you find is the cause.
It may very well be the bushing under the gear shifter. They wear out and crumble away and make shifting hard. Pull the boot and the 4 bolts holding the top plate for the shifter and see if the bushing is crumbling/tearing up. BTW there is a spring under the top plate that makes the shifter center up, try not to lose it and look at it when you get it out. Good luck.
Last edited by reelal; 01-01-2022 at 08:24 AM. Reason: added a line about the spring.
