Steering "issue"
Steering "issue"
So yesterday i got my 4runner stuck pretty bad. Now when im driving straight down the road my steering wheel is upside down. I checked it out, nothing looks visibly bent...what did i do?
Take off steering wheel and turn it 180 degrees. To get to it remove your horn (should be a screw maybe two on the bottom) I believe it slides up (towards normal top position) and then remove the center nut holding the steering wheel, and rotate.
Sounds like something slipped, time for high steer?
I bent my tie rod pretty good last time I was out wheeling, for me its time to ditch the stock push/pull steering setup and convert to high steer. Just ordered up everything I need for the swap last night
Are then ends of your drag link parallel?
Is there excessive play in the wheel?
I Wedged myself last year on the Rubicon and broke my stock steering. It both bent the J-arm and shatted the coupling between the J-arm and the Drag link.
Have you jacked the front of the truck up and played with the steering, turing the wheels by hand? You'll have to have the steering column unlocked to do so.
After breaking mine, i converted to crossover steering and couldn't be happier!! : ) But I also added Power Steering while I was at it.
Good Luck with it
BTW Great Lookin' Runner!!
Good Luck with it
My dad should be coming over later to help me with it, steering is one thing ive never really delt with. But yeah i found a hi-steer kit an ifs box on craigslist, but i don't have the money right now. Thanks for the compliment, its an awesome rig
It's not the cheapest setup out there, but i like the www.4x4labs.com crossover setup. Check it out, it moves the tie rod behind the axle. I don't have any experience with it, but someone showed me the website a while back and I like the concept a lot.
Keep us posted as to what's the issue and how you resolve it. : )
If that's an option, I would Definitely Jump on it! Just keep in mind that you'll have to purchase an IFS Steering box also. Be it rebuilt, new or used. I went the Used route and also got the Power steering pump with all the mounting hardware for the same price that I found just a rebuilt box for. But I assume you have PS, so it'll be cheaper just to pick up a used steering box.
Steering is one of the most important components of a vehicle. You need it to work, be safe and Reliable at all times!!
Good Luck!
Good Luck!
live4soccer7
05-11-2016 06:52 PM
scott90
10-04-2015 09:21 AM
