Spring Shackle Bolt HELP!!!!
I am having a hell of a time getting the from spring shackle bolt out on my 88 4Runner. I got the right spring removed already and the left is ready to come out but I CANNOT get the front bolt to come out.
I have hammered on it, impact gun, breaker bar, i can feel it snap with the breaker bar. It feels spongy and then it snaps once each time i put the breaker bar to it. But the son of a bitch won't come out!!! I need this thing out today so I can go and get my springs re-arched and an extra leaf added.
HELP!!!!!
p.s. the nut is off the bolt, the bolt just won't come out of its hole. The bolt is turning though
HELP!!!!!
Then torch it out (the bushing) and then u can (maybe) reuse the bolt...
I can tell ya that er is seized to the rubber on the bushing....banging on it with a hammer/impact/whatever wont do a thing
What is probably going on is that the shackle pin has rusted inside to the bushing. That is there is a big lump or rust+rubber on the pin in the center of the bushing. What I found that worked on my '85 was to sit the spring on it's side and soak with penetrating oil (petroleum-base to soften the rubber) and then twist the shackle and let it sit for a while then repeat. Took about a half a day to soak enough oil in there to soften the rubber enough to allow the enlarged section of the pin to come out of the bushing, which happened when twisting the shackle and using a pry bar underneath to lever it up. The stock shackle pins are not easily replaced, so it you do have to cut it, plan on buying new shackles. Maybe the spring shop can press the pin out.
It does need to be the correct grade and size...no questions
It is not really a bolt, per se. It has a flat round head that is pressed/welded into the shackle side plate and then has a stepped down shoulder (from 18mm to 14mm diameter) with the threaded portion. Not going to find something like that even at a specialty fastener shop. I doubt even Toyota would see you just that pin, probably need to buy a new shackle or modify the shackle plates to take a regular bolt.
I have some tips on removing the spring hanger bolt (if that is what is being referred to) below (see the 4th Q&A):
http://www.4crawler.com/4x4/TLCA_Tru...ech.04.01.html
I just did mine and had the sme problem. I cut the old shakle plate, and the top bolt came right out. The bottom wouldn't budge. I put a big pair of channel locs on the end of the bolt and twisted it around. A ton of rut and crap came out, then I was able to get it to come out.
if it's the spring hanger bolt it's easy to get out. grind both ends of it down till they're flush with the hanger on the frame, and then drive a claw hammer in between the spring and the hanger (to spread it out). you'll see the ground ends of the bolt pull into the hanger and you can force them in and down. took me about 15 minutes to do both sides.
once i cut the old bushing out i measured the bolt and went and bought grade 10 replacements. new poly bushings and you're golden.
thanks for all of the tips.
a sawzall and few blades later i have cut the bolt. the springs are now at my local spring shop getting re-arched and an extra leaf added. hopefully they have a new front bushings to press in because my old ones are shot.
upon further inspection of the bolt from the side that came apart, it is not a specialty bolt at all, just hardend. I thought it had a special shoulder on it but that is not the case.
Yep, on the '84 and later trucks, the rear spring hanger bolt is plain since it goes through a sleeve in the bushing and thus does not need the shoulder. A Grade 5 or 8 9/16" bolt will work fine, or 8.8 or 10.9/14mm if you want to stay metric.
Flying91
45
04-11-2024 04:39 PM
Jcrawl94
10
10-24-2015 04:34 PM
Shagool22
08-14-2015 12:24 AM
