RUF need help
RUF need help
I have an 84 toyota, I have 2 stock rear leafs, im putting then up front but the hanger is 18mm bolt and the springs a 14mm hole in the bushing hour do I attatch the spring to the hanger with the different size holes?
Some options:
1. Remove steel sleeve in existing bushing, viola hole = 18mm ID.
2. Replace rubber with poly bushings and omit the sleeve and hole = 18mm:
- http://www.4crawler.com/4x4/ForSale/...l#PolyBushings
3. Get some '83 or earlier springs and they use bushings w/ 18mm holes
4. Weld plates over spring hangers and drill 14mm (9/16") holes in them.
5. Cut off spring hangers and replace with hangers with 14mm holes:
- http://www.4crawler.com/4x4/CheapTri...ringHangerDrop
6. Take the funky OEM front spring hanger pins and have a machine shop turn down the 18mm section to the 14mm threaded dia. that is on the ends.
The large 40mm OD bushings are used in some spring eyes on the later trucks
In OEM form, these bushings have an inner and outer sleeve and are pressed into the spring eye and need to be cut or pressed out to replace.
The bushings have a removeable inner sleeve to allow use of either 14mm (9/16") or 18mm (3/4") hardware
Cost is $20/pr.
Cost is $20/pr.
Dang when your title said "RUF" I thought you maybe owned a RUF... I almost peed myself thinking I could come to the bay area (from Sacto) and see it in real life...
RUF = EXTREMELY upgraded Porsche, to the extent that they are considered their own car manufacturer... AKA Bassinfool's dream car.
Anyway sorry to hijack your thread I just had to share the beauty that is RUF.
haha everytime I here about a RUF porsche I think of Rears Up Front lol
as far as the springs on my 85 rears I just pressed out the bushings and sleeves and used 40mm bushings from marlin
RUF is actually the name of the owner/creator of the company. Alois Ruf, Sr started a little garage, Jr. then made it a performance shop in the 70s.
A BFH will get the sleeves out. If they are bonded to the rubber, then ur effed. Replacement time....
2. See if you can get a hack saw blade inside and cut outwards to split them in 2 or more segments and then try to remove each piece.
better get new bushings now, cus the ones in there aren't gonna come out in two pieces. lol. Only problem running the no bushing way is you have to be extremely careful not to overtighten the bolts. Torque specs go out the window too. Nyloc nuts or those capture type nuts should be used to lock the bolt otherwise you'll have problems with it wanting to back itself off.
I've never actually heard the term DP Porsches. I know the 935 Slope well, but that is a first for me. I'll have to read up on them.
justdifferentials
14
06-11-2017 08:36 PM
live4soccer7
05-11-2016 06:52 PM
Toys4parts
09-26-2015 01:56 PM
