Rear wheel cylinder on 10/85 build date
Hi, i have a 10/85 build date 4x4 with long bed.
guys at parts store are totaly confused which wheel cylinder to get...so i am.
is there any upgrade that i can do ?
i searched, didnt find anything about the rear wheel cylinder themselves, only the MC.
It got already IFS with vented rotors and big drums (oem).
thanks for any comments.
well, he ask me for the build date, but also if it is a 1/2 ton or 3/4 ton.
looooong time ago, the dealer told me it was a 85 1/2
I always say its a 86'.
no upgrade (larger cylinder) ??
thanks.
thanks.
What is the front suspension? A leaf spring/solid axle or IFS w/ torsion bars?
perfect, thanks...
since i have your attention...i plan to add a snow plow on this truck. since it is a IFS, there is no coild spring to play with.
is there something that can be added like a coil-over helper ??
thanks.
thanks.
You can add heavy-duty torsion bars to offset the weight, or go on the cheap and just crank them up a little bit....be advised thats not the best way to do it since you will have a harsher ride, and risk damage to the bars from the added stress.
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
icentropy
07-09-2015 02:12 PM
skoti89
07-06-2015 07:45 PM
