push pull steering problems possibly
on my 84 toyota where the first arm that comes off the arm on the steering box that had the adjustable screw on it. what exactly are they called and where do u get em at? i need the 2 on each side cause i tried adjusting htem but they got quite a bit of play still and im getting a pop when i turn kinda sharp. and the tires are kinda gittery fomr the play in the steering. thanks
We bought them at NAPA. Repair kit for the drag link. Kit does one end, so you need two kits
http://napaonline.com/masterpages/NO...ink+Repair+Kit
thanks!!... also this is kinda off topic cause i dont wanna start a new thread. ive got some low oil pressure so i tried to change the fram filter with a better flowing one but it still has low pressure. i heard of a relief valve on the pump and if thats not working will it cause my oil pressure to be low, can u get to them without tearing stuff apart and do they sell em without the pump? im prob just ognna do the chain and pump soon but i would like to see if this valve fixes it
Jnkml
07-06-2015 01:20 PM
