pulling dash apart?
pulling dash apart?
i have my dash apart, well most of it. i cant figure out how to get behind the air con to change the light color. i changed my cluster color but it looks horrible with green on the aircon lights, just wondering if anyone knew what to look for or if there are good write ups for it
If your trying to get to the light bulb on the heater control thats a real pain in the butt, the light socket snaps into the back of the heater control, so you can either disconect the hearter control cables and pull the control out, or remove most of the dash to get to it, wich ever you think is easier. its very easy to remove the dash, or atleast i think it is because ive replaced a couple of heater cores so ive done it a couple of times.
remove the knobs from the heater controls and carefully pry the face plate off. the bulb is located in back. it may make it easier if you remove your ashtray and the bracket to hold the socket from the back when installing replacement.
also, while i have the face off.. my low does not work on the air con, all the other settings work except low, i did not knwo if this would be in the switch or somewhere farther back. anyone know?
Blower motor resistor is located right behind the blower motor itself... closest to the firewall. Two bolts that should be 1 to 2" beside each other with a rectangular plug in the middle. Removing the bolts exposes the resistor.
probly not, if it does its not going to be too expensive at a wrecking yard. id go get another one anyways and try it. i have had the same experiences with only one speed not working and every time it was the resistor but ive never had that problem with any of my toyotas=) just check the switch first just because its easier to deal with, resistors can be hard to find.
I disagree. I believe it may be the resistor, as the 2nd gen trucks (1st gen runners) actually have a seperate resistor coil for each individual terminal. They're very fragile and are bent and broken very easily. Its generally a common problem.
By 1991, someone was smart enough to encase the coils to prevent damage caused just by handling the unit.
ashersullivan88yota
01-18-2022 05:37 PM
jasonty
41
12-23-2018 01:00 PM
Esibnitsud
07-30-2015 08:21 PM
