pinion bearing?
Old 10-12-2015 | 04:55 PM
Waylayer's Avatar
pinion bearing?
Looking to do a pinion bearing on front axle on sas 4runner, looking for a tutorial of some kind on doing that. Or if someone call write a sort of set by step with a list of tools needed. I'm guessing I'll need gasket seal, grease and gear fluid. Going to change seal too. Have done sine reading and research on it, so far I'm confused if I can just pull pinion and replace without reloading. Heard I may not need a press to swap bearing too. So not 100% sure on this.
Old 10-12-2015 | 08:36 PM
58rennur4's Avatar
There are some decent videos on YouTube that cover this and the entire front/rear axles.
Old 11-25-2015 | 06:14 AM
greQ's Avatar
Make sure you have the socket to fit pinion nut too. 30mm or 1 3/16". And for the love of everything holy remember to stake the nut when you are done
viesail
08-17-2015 08:39 PM
trailgoat
08-13-2015 05:54 PM
nonstop
7
08-11-2015 09:26 AM
norcal98
08-10-2015 06:20 AM
dfarr67
07-30-2015 07:08 AM
Quick Reply: pinion bearing?
