No power to fuel pump with test jumper jumped
Old 12-11-2008 | 12:09 PM
desertcamper67's Avatar
Hey, I am a newbie and have looked down a bunch of threads looking for my particular problem. My '85 4Runner was stored for 2 years, battery replaced and driven twice. The next time it wouldn't start. I checked and do have spark to the plugs. The next thing I checked was for power to the fuel pump. I have checked this in the past by just unplugging the plug to the tank and checking the plug coming from up front with a 12v test light. On my other trucks it would pulse when cranking. This time it didn't pulse or anything. I tried jumping the test plug on the driver side fender (the non-round one) but still got nothing.
Where do I go from here? Please help.
I was so suprised that this old truck of mine is giving me any trouble as it has been ultra dependable for years.
Thanks
Old 12-11-2008 | 12:22 PM
scuba's Avatar
EFI fuse...? 15A in fuse block...
Or the big EFI relay...
if not CIrcuit opening relay...
Old 12-11-2008 | 01:19 PM
4Crawler's Avatar
Do you hear the CO relay in the passenger side foot well area click when you turn the ignition on with the test jumper installed?
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
If not, that relay or the wiring may be bad or any of the fuses or relays upstream from there. If it does click, then check the wiring to the pump for continuity.
Old 12-11-2008 | 07:10 PM
okay thanks guys. I'll look at it again tomorrow. 4Crawler, hey I saw your name all over these similar posts and it seems like you know your sh**. By the way nice truck. I didn't hear or notice the sound coming from the pass. kick panel the fes times I tried it today with the jumper. I'll pay more attention tomorrow.
Old 12-12-2008 | 10:43 AM
Okay today I cranked it over and did notice a click in the cab but it didn't sound like it came from the pass kick panel at all. It kind of sounded like it was coming from the dash somewhere. I stuck my head in through the passenger door to listen while I cranked it over and the sound seemed to come from the middle of the dash. Of coarse still no start.
Old 12-12-2008 | 10:55 AM
4Crawler's Avatar
Sounds like the circuit openiong (C)) relay is not working:
- http://www.4crawler.com/4x4/CheapTri...ORelayLocation
Old 12-12-2008 | 12:06 PM
I disabled the starter as you suggested and took the kick panel cover off and I definately heard the clicking of the relay. Thats the circuit opening relay, right? Do I still need to test it or is the clicking a confirmation that it is working? I haven't actually taken the ECU out of the way to see this clicking box yet.
Old 12-12-2008 | 01:35 PM
scuba's Avatar
Have you tested the AFM yet...
Sounds like theres a problem with the power getting from the FP to the COR then back the the AFM....
Old 12-12-2008 | 07:21 PM
Thats inside the air filter box on my year I believe. So how do I check it?
Old 12-12-2008 | 07:25 PM
4Crawler's Avatar
The AFM is inside the air box:
- http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
But it is another thing that makes the CO relay turn on when the engine is running. If the CO relay is not turning on with the test jumper installed, then the AFM won't make it turn on either.
Old 12-12-2008 | 07:44 PM
I do hear the CO relay click when I turn the key to start. Does that mean its good?
Old 12-13-2008 | 12:38 PM
The CO relay clicks with the test jumper installed or not installed while cranking.
Old 12-13-2008 | 12:41 PM
4Crawler's Avatar
Well there are two parts to a relay, the magnetic coil and the contacts. Clicking means the coil is intact and magnetizing when power is applied (either via the test jumper or via the STArt signal). But if the contacts are dirty or pitted it may not be making electrical contact. To test that you could pull the relay and insert a jumper into the two output contacts pins on the relay socket and see if the pump gets power. If so the relay is bad, if not the wiring between the relay and the pump is bad:
Old 12-13-2008 | 01:20 PM
scuba's Avatar
GENIUS !!!
Old 12-13-2008 | 02:26 PM
Thanks. Excellent explanation. I was just going to take out the relay but then some wet stuff started to fall from the sky. I'll just kick it until this rare socal phenomena ends. I'll let you know what happens.
Old 12-13-2008 | 03:05 PM
scuba's Avatar
What part of SD are you in...?
Im hoping the rain will sorta wash my truck...
Im up in temecula if you know where that is...
We should hit up ocotillo that is when the truck runs
Old 12-13-2008 | 03:16 PM
Oh hey, I'm currently living in Valley Center.
Old 12-13-2008 | 03:20 PM
I'm currently in Valley Center. Yeah Ocotillo is cool but have you gone pass there to Truckhaven? Lots of hills there.
Old 12-13-2008 | 04:35 PM
mistreatedtoys's Avatar
I had the exact same problem on my 86 turbo 4runner. I converted it to a regular 22re. Never did find the problem I checked all the stuff you talked about. But mine seemed to be intermitent about the time I think I had stumbled upon the problem it would mess up again. I finally gave up on this truck and wired a jumper off the cigerette lighter.
Old 12-13-2008 | 05:22 PM
so you had power to the fuel pump constantly? Just not when the key was off?
Quick Reply: No power to fuel pump with test jumper jumped
