New shocks needed w/ ~2in lift?
Old 03-14-2007, 10:24 AM
4Rocker's Avatar
Just wondering if new shocks would be needed when putting a small lift (such as the OME springs) on an 84 to get rid of the saggy originals. Ive got a set of Rancho 5000s on there now and theyre still pretty decent. Would anything other than springs and bushings be needed for this setup? Rocky road has the OME springs for about $86 each and im thinking this may be a good upgrade in the future.
Old 03-14-2007, 10:36 AM
deserttoy84's Avatar
i was thinking about buying the same springs form that place also(just for th front for now though). I doubt you need new shocks. only thing i could see might happen is on full droop the shocks might limit the travel
Old 03-14-2007, 10:46 AM
4Crawler's Avatar
Put the lift on and try the old shocks. If they limit droop too much, then new ones could be installed. All depends on how long the existing ones are. If they are a little longer than needed for the stock setup, they may be fine with the lift. You can also space down the upper mount up front for a little more droop.
Old 03-14-2007, 10:51 AM
HUTCHSTACO's Avatar
should work...like said above...depends on the length you got in there
Old 03-15-2007, 07:09 AM
4Rocker's Avatar
The shocks that are in there now are Rancho RS 5000s. Not sure of the specific part no, but they are stock length replacements. I just wasnt sure if I would run into problems with the shocks trying to over extend if the axle can droop more.
Old 03-15-2007, 07:57 AM
4Crawler's Avatar
You can find the p/n stamped ont he shock and look up the specs:
- http://www.4crawler.com/4x4/Rancho.shtml
One simple check you could do now is to lift each axle off the ground and measure how much extension you have on each shock and thus find out how much (if any) additional extension length is left.
Old 03-15-2007, 08:17 AM
frodin1's Avatar
You shouldn't need new shocks. I ran the stock ones with a 2.5" Daystar spacer and never had any issues. There should be enough travel.
ZGjethro
06-07-2017 11:04 PM
live4soccer7
05-11-2016 06:52 PM
voiddweller
10-02-2015 07:47 AM
dirk89
10-01-2015 05:15 PM
myotherrideisayoshi
09-29-2015 05:41 AM
Quick Reply: New shocks needed w/ ~2in lift?
