Instaling Clinometer
im trying to get my dashboard off in my 85 runner and it seems like its bolted on the right side top... their was a clip on the left side and looks like bolts or just really stuck in with clips... i just want to make sure its clips befor i pull my heardest to tear it off... i cant pry on it because i dont want to crack the windsheild... anyone know what to do?
Clinometer Mounting
Thought I'd resurrect this post. I have an '88 pickup and I just bought a used Clinometer, complete with wiring harness, for it. Can anyone tell me if the holes are already pre-drilled and if the wiring connector should already be in place? Also, I looked at my FSM and it doesn't show much. Will I need to cut away any of the dash pad or does the Clinometer mount right on top of the dash pad essentially sandwiching the pad between the Clinometer and dash pad frame? Thanks!
dannydsmv
1988 Toyota Pickup V6 5spd SR5 Xtra Cab
2003 Subaru WRX Wagon
2001 KTM Duke
dannydsmv
2001 KTM Duke
88 SR5...you'll find the other end of the plug for your clinometer already in the dash.
Flip the dash top over after you get it out and you'll see the holes pre-drilled where the studs and the wires from the clinometer go. No serious cutting, but it isn't really a "reversable" addition with the new holes in the dash.
It won't make a difference SR5 or not, the wiring harness on the inclino has male and female connectors. The connectors are daisy chained with the climate control lights. Unplug the climate harness, plug the inclino into that and then the other inclino connector to the other half of the climate control.
punks_is_4x4
08-21-2015 01:35 PM
Esibnitsud
07-30-2015 08:19 PM
1986, 1989, 4runner, 91, clinometer, inclinometer, install, mitsubishi, montero, smittybilt, sport, sr5, toyota, truck, wiring
