How much did I mess up?
I change the transmission fluid on my 84 pick up last night I took out the bolt that Says “do not remove” thinking that was the area where I had to fill in that fluid the bolt was dirty so I didn’t see it that it said do not remove until I cleaned it but anyway, I took out the drain plug after and filled in the transmission fluid it took all 4 quarts nothing came out or jumped out of the area where I took out the hex bolt from like parts wise. Anyway did I just messed something up big time? this is the first time I’ve done this in this truck I just recently acquired. Any suggestions? This was last night so I haven’t driven the truck I am currently at work and will drive it maybe tomorrow I didn’t change gears or anything while the bolt was out. I stole this picture from another person in this forum for a reference of which bolt I took out it is the top left in the picture. It wasn’t until I research and found out that the actual fill plug is on the top right. Thank you
Zcostilla
05-31-2020 07:31 AM
Ruined Adventures
03-29-2011 01:06 PM
fireteacher
9
10-12-2006 08:34 PM
