Help!!! No spark!
Help!!! No spark!
I recently replaced my heater core in my 85 22re yota. Everything is hooked back up inside and ive checked the battery, distributor, coil, fuses, ignitor, and plugs. It will crank over but no spark and its getting plenty of fuel. I dont know where else to look. Anything will help. Thanks, Derek
Now im not getting any power to the ignitor. Does anybody know what that means? Again if you have any ideas let me know. I also heard that you can hot wire the ignitor if any body knows how to do that.
I had a 22r that had a broken wire inside the insulation. This wire was coming off the + side of the battery and was small sized but it kept the power from the igniter. So I jumped a wire from the battery + to the coil and the dash lit up like no problem. The wire might have gotten bumped during work on the heater.
zytra
01-24-2019 03:16 PM
