Diagonal Adjustment of Door?
Is it possible to adjust the angle of my drivers side door diagonally? The top of the window frame the door sticks out maybe 1/8", gradually tapering out from the bottom of the window which is flush with the body.
It's letting air in so whistles on the highway.
The body side of the hinge is your up down, the door side is your in out twist.
Odds are someone pried the door open to trip the lock and you just have to bend the window frame back into a shape that matches the cab.
