Charging System Problem? ? ? ?
Hey Guys ____ WHERE is the” voltage regulator” LOCATED on an 84 22r 4runner, I know on an 85 22re it’s in the alternator. I’m having symptoms of a faulty alternator. Charge light on, its running rough, and the tachometer is going crazy (up and down) wipers slowing down. I did tap on the alternator once and the symptom disappeared but came back, I’m also thinking intermittent alternator (worn brushes) problems, had it checked out, it was good. So, just for good measure I’m going to replace the voltage regulator for good measure and go from there. Any ideas are WELCOMED ________ THANKS in advance BAYRUNNER
Avenged
07-09-2015 07:55 AM
