brake upgrade on 84 sfa to ifs calipers and land cruiser rotor
i am planning on upgrading to the vented rotors from the land cruiser , what year land cruiser rotors do i need? can i use the bearings and seals from the original 84 rotors. any tips?
Use the rotors from a FJ60. You will need the larger calipers too (the vented rotors are thicker)
You keep the housing (hub) that the bearings go into, so if your bearings are good, pack with grease and re-install.
The calipers I used (on my fj40) were from a 94 4Runner (I had to cut the backing plates to make them fit). You could use the calipers from the FJ60. I don't think they would require the trimming
yea i realized the hub is removable after i posted.. dee dee dee!!
i have calipers from an 89 v6 ifs rig. i just need to know what year fj or what exact vehicle , year and all, to tell the dumb guy at the parts store to get me the rotors for.
i have the backing plate eliminator so i dont have t worry about that, my only worry is i may need a spacer but im getting new wheels and tires soon anyways.
and i just found this....
http://www.barneymc.com/rtr_swap.htm
Heres the thread from when I did mine .... front works great.
https://www.yotatech.com/forums/f115/v6-caliper-brake-upgrade-question-78207/
P.S. I did need wheel spacers.... use red locktite and retorque as directed for peace of mind.
very good write up, thanks alot.. i didnt know the 92 v6 was different, i have been on advanced auto parts' website crossing part numbers and i noticed they were all the same number on the l4 and the v6 up to 91 i was thinking it was a mistake or something. so if anybody needs calipers for the conversion use a 92 up v6 caliper with the rotors from a 81-90 land cruiser. band a 94 non abs 4 runner master cyl.... viola...!! guess i should have searched.
06-01-2021 01:51 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
terminator
07-27-2015 07:13 PM
