Belt issue
Belt issue
I am having trouble getting my power steering belt to line up. From the upper pulley that is adjustable, down to the crankshaft pulley, the belt it as at a noticeable angle. I recently replaced my power steering pump, and this issue came up. The new pump is the correct one, I even tried the pulley off the old pump. I've also tried every thing I could possibly think of to adjust the top pulley. I tried a 2nd belt and it was a little better, but it was not a new belt. I pitched the belt off 3 or 4 times this weekend out in the desert.
Thanks
Thanks
PS pump should have nothing to do with it starting. I have determined that I need a 3 groove crank pulley. Some how it worked on a 2 groove up until now.
IIRC the outer groove on the 3 groove pulley is for A/C...isnt' there a spacer/washer thingy on the ps pump pulley? Someone else had this problem and I think that was the issue...
There is not really any way you can put a spacer on the PS pump. It bolts on with 4 bolts and the pulley shaft has a tooth that the pulley has to slide in on. 3rd (bolt on) pulley is going on saturday, problem solved, time to race!
WellsR
12
07-31-2015 03:27 PM
TJWilly
07-31-2015 02:05 PM
cgilley
07-25-2015 10:55 PM
