Those seats all look nice. I plan on removing my bench seat sometime. Do the Prelude seat rails actually line right up or is there some adjustment that needs to be done?
I did have to do some additional drilling. With that, in order to get the seats at the right elevation, I also had to get some washers to use for spacers. As a recommendation, only use real bolts. Don't skimp on fasteners at all. The bolts will hold down your seat belts and that is all you have between you and the windshield and/or going through it.
Hope this helps some. |
That's good advice. I don't want to eat the windshield should the worst happen. Did you put any kind of sealant or something around where you drilled?
