axle shims
axle shims
I'm sure this has been covered on more than on occasion, but I need to know the degree of angle of shims I need on a three inch lift. When I bought the truck they were not there...
no one can give you an exact number. You'll need to measure your pinion angle and t case output to determine the right shim. lots of varibles to take into account.
1 or 2 piece driveshaft.?
double cardon joint at t case?
vehicle wheel base?
stock or extended shackles?
etc etc etc.
for my truck, 84 ex cab dual t case, i didnt need the shims that came on a 4inch lift.....
vehicle wheel base?
etc etc etc.
TheBFA
02-15-2020 06:55 AM
FS[MidAtl]: fZJ80 9.5" rear axles w/ e-lockers complete
I8URSVT
10-05-2015 07:23 PM
Cycles
09-29-2015 06:37 AM
Toys4parts
09-26-2015 01:56 PM
