auto trans and body lift
At 1", generally no issues with the A/T linkage, at 2" and above, you need the bracket kit, as noted above:
- http://www.4crawler.com/4x4/ForSale/...o.shtml#Taller
Here is the full 3" bracket kit installed:
From: Houston (home), Atlanta (school), Cincinnati (work)
Correct, if you raise the transmission an amount equal to the body lift it is is if there were no body lift, same deal with the radiator brackets, radiator goes up with the body and the engine fan goes up with the engine, negating the offset of the lift.
06-01-2021 01:51 PM
09-04-2015 09:27 AM
D.B.T. 87 4x4
07-20-2015 04:51 PM
