Another front cab leak thread.
The PO of my pickup said the windshield leaked. After I picked it up there was a pretty good rain and no water came through. I had a windshield guy come by and check it out anyways. Dude had a look and inspected the inside and said it's not the windshield. He said it's likely the cowl drain being plugged from debris. He didn't remove the moulding and didn't look at the windshield from that vantage. It's raining pretty good now and there is water making it's way in. I'm at work so I've just got a quick shot of it. It's made it's way in somewhere and running just below the glove compartment. No water in the actual glove compartment. What's everyone think? What's the first thing I need to start digging into this thing when I'm off work?
A few pics
A few pics
Dug into this a little tonight. I’m convinced the water isn’t coming from the cowl. It’s got to be from the window.
To me, the cowl looks solid, inside and out. The spot it drains looks good on both sides too.
Passenger side:
Driver side:
If I’m missing something, let me know. Also, let me know if there’s somewhere else I should be looking into this. Otherwise I’m going to be having the windshield guy back.
Passenger side:
Driver side:
I'm dealing with a similar situation and the glass guy said about the same thing. What glass company are you dealing with? What about removing the glove box/ducting under the dash and using a hose to be sure it's not the cowl leaking, That's my plan. I think it's the windshield. Another thing is the seam seal in the gutter above the doors. If the seam seal has deteriorated and water is getting in, it can run down the A pillar and onto the floor. Let us know what you find out, a leaking cab is no way to live.
Under the hood just below the cowl is possible, but doesn't seem to match that well with where your puddle is. Here's a thread that may help.
https://www.yotatech.com/forums/f116.../#post52458297
Just a local place called First Class Auto Glass.
I’ll look into this when I get back home. I pulled the glove box and pulled up some of the carpet. The carpet was pretty wet, so water was getting in and running down more than just onto the weather mat. Here’s a picture looking up through where the glove box would sit. Looks like some water was running onto and around the ducting and dripping off.
Here’s the puddling water under the carpet.
Here’s the best picture I’ve got under the hood. I don’t see a seam at the inner fender and firewall that could be leaking. Maybe I’m not looking at the right spot. Let me know.
I’ll have to look into the gutter seal too. I know there’s some surface rust there. I’ll have to run some water down it and see if it makes it into the cab.
For sure. Here in the PNW, if you’ve got a good leak, which I do, you can go months without getting the cab completely dried out. That’s not something I’m going to put up with.
Once in a while I get a similar leak like this through the blower motor. I did have to rebuild a lot of that inner Cowell though. I tried to cover that opening above the vent but it sucked the cover in. I need to put the screen back in.
Something still leaks on the driver's side too. That one seems to be the clutch MC. It had a gasket to the fire wall and it must have been disturbed when I replaced it. I'm not 100 percent sure it isn't the windshield though. It was replaced a year ago and who knows there.
Is the blower motor wet from any of that?
You might have came across this but if not it’s a good thread for the windshield,
https://www.yotatech.com/forums/f116...-maker-107858/
I consider myself lucky with my windshield, the last one I got I hung out with the tech and it looked pretty solid, I did get rid of the chrome trim though as it was pretty tattered and the black looks better to me. I wouldn’t pick your brain apart until you verify the windshield status
Bad Gutter SealCaused My Leak
Check the seal on the gutter. That's where my leak came from. Water somehow wicked to the front toward the upper corner of windshield surround.
Tape in photo was applied to eliminate doubt on the windshield mounting/adhesion.
MORE DETAILS HERE: https://www.yotatech.com/forums/f199...l#post52348553
I dug under the dash much more. I could see a spot when water had been dripping in. You can see the stream of rust coming down.
I treated that spot from the outside but can see that at the spot where water has really been running in. I ran water down the windshield and couldn’t get anything to drip in. I should have put some water down the drip rails. I can do that tonight. Here’s what they look like.
They don’t look all that terrible to me either. Maybe it’s just enough to let water in.
I’m going to highjack my own thread for a second. After removing the glove box I noticed some wiring connectors that weren’t plugged into anything. I didn’t look real hard but, I didn’t see anything they should have been plugged into. Anyone know what these connectors should go to?
I have a feeling I’m just going to have to get a windshield guy to remove it and the problem will be clear as day.
It’s raining today and I nailed down two contributors. Looks like the grommet the wiring harness goes through is leaking, as well as a whole right below it. You can see a bead of water already formed coming from that whole. It’s nice to know I’ve for sure found some spots.
Here’s where some is coming on the inside.
Here’s where it’s coming in from the outside.
Now I’ve got to figure out where the water was coming in that was running down the bottom of the glove box and onto the rubber mat, in the first post. No way the two spots pointed out above are the source of that.
It's raining more today. Work on the cowl/firewall/kick panel is definitely in order. I really want to tear into this thing and bomb proof the entire area. It would take some time but, I'm over this leaking cab.
Why you trying to kill my day like this. I was having a good day and you come along with this and try to kill my vibe? On a serious note, I'm going to put up with it through the winter here and really get after it this spring/summer when things dry out.
I'm not trying to kill your day, the rust maker frame trim is😁 a lot of people have eliminated it. me too but I'm not in love with the look , we didn't have all the trim anyhow. I thought I could switch to the rubber gasket seal but the windshield is a different size.
Put gorilla tape around it on a sunny day.
SolidDigital
12
11-08-2012 08:33 PM
