Alternator crapped out
Old 01-28-2010 | 06:54 AM
Outsane's Avatar
Last night went for a run
got back in the 4runner and about 1/4 mile down the road lights dimmed and my volt gauge dropped to the midway mark. Revving the motor didn't bring it back up. Finished the drive home another 1/2 mile and the needle dropped a little more.
Got home left the truck running, pulled the Neg battery terminal and the engine stopped running. Checked the wiring and every seemed fine, I have added an extra 2 awg from the Alt to the battery as part of the big three.
I want to drop in a alt I can pick up at the local parts store, with out waiting for brackets and what not, and gain some amps. Since I am supposed to drive to pick up some parts on Sat with the 4unner.
From what I searched
90 Cressida will give me 80 amps and will drop in. I just have to bypass the external voltage regulator since I have an 84 4runner.
Any thoughts?
Old 01-28-2010 | 07:21 AM
874runnersr5's Avatar
I also think there is a GM alt you can drop in, not sure on what one or how much work needs to be done, but 80/90 amps is pretty good.
Old 01-28-2010 | 07:28 AM
Outsane's Avatar
from what I have read you need a longer bracket to mount the GM one...
Old 01-28-2010 | 07:33 AM
ah nevermind then, go with the cressida since is plops right in.
Old 01-28-2010 | 08:01 AM
Outsane's Avatar
sure would be nice to 140 amps though
Old 01-28-2010 | 05:09 PM
myyota's Avatar
I just bought a 160 amp alternator for my 86 4Runner, Its a rebuilt toyota alternator.
I got it from
pro starter and alternator
619-888-7202
pro.starter.alternators@gmail.com
there located in san diego.
Old 01-28-2010 | 07:25 PM
Outsane's Avatar
I will have to give them a call
Old 01-28-2010 | 07:51 PM
myyota's Avatar
If you have an 84 4Runner then you have an external voltage regulator, you will need to do some rewiring to make the later style alternator work, but its not hard to do.
Old 01-29-2010 | 06:23 AM
Outsane's Avatar
Great info myyota..
I was looking at this link for instructions on how to bypass the old voltage reg that is bolted down to the fender wall
oops wrong link... there was another one with pics of the regulator plug.. need to find it
Crap can't find the link
Old 01-29-2010 | 07:02 AM
Outsane's Avatar
http://home.earthlink.net/~twopapa/bigalt.htm
link found
Old 01-30-2010 | 12:29 PM
kcpanages's Avatar
I got it from
619-888-7202
whats the cost on the 160 amp alt. ive tried calling them several times with no answer
Old 01-30-2010 | 05:32 PM
myyota's Avatar
It cost me 165.00 shipped. I bought it from them off of ebay. I recieved it about 4 days after i ordered it.
Old 02-01-2010 | 07:35 AM
kcpanages's Avatar
shot me a link to the ebay page. cant find them. Hows it working?
Old 02-01-2010 | 07:40 AM
Outsane's Avatar
so far its sitting in the garage.
I needs a new alt bracket after all.. and my plug is different
the 84 is different then the 85 and up
Old 02-01-2010 | 07:21 PM
myyota's Avatar
You can give pro starter and alternator a call at this number,
619-282-3207
Old 02-01-2010 | 07:39 PM
84toyota4x4extcab's Avatar
i have an 84 pickup and i was able to put in a gm alt without changing any brackets i just had to cut the plus ins off and wire in some gm ones
Old 02-01-2010 | 09:09 PM
Outsane's Avatar
oh hell
Old 02-01-2010 | 09:25 PM
myyota's Avatar
Originally Posted by Outsane
oh hell
Believe me, i said more than that, i was pissed that they just couldn`t tell me in an email, so i will try and call them tomorrow.
Old 02-01-2010 | 09:29 PM
RMA's Avatar
RMA
hahah..it will be ok ..
Old 02-01-2010 | 09:48 PM
iceboxx2514's Avatar
the gm alt is called a CS144 and you can get them built up to 200amps and the are a single wire alt that mounts directly in place if there is any mods to be done it would be to grind the lower ear on the alt down a little but my customers generally dont have any problems
Quick Reply: Alternator crapped out
