85 Auto tranny
85 Auto tranny
My 85 pickup 4WD has a auto in it and the OD likes does not come on and when I'm driving on teh highway it goes into OD but when I press teh button on the shifter it doesnt do a thing or even light the light up. Whats the Problem? Auto trannys SUCK. LOL
no you need a little computer diagnostic tool thingy. the bulb (I'm assuming) completes a circuit or something and, if the OD does not work, the computer you hooked up will tell you that.
Thatstill doesn't make sense to me, but that's how I interpreted it.
Replacing the bulb will tell you where the problem is at though.
All you do is find the square plug shown below and ground it. You don't need to use the volt/ohm meter as shown. Switch the ignition on, don't start and make sure OD is turned on. If you have any electrical problems in the tranny it (OD light) will flash one of the codes below.
tinigunner11
08-14-2015 01:19 PM
Iceman4193
07-15-2015 04:48 PM
