85 22re problem
85 22re problem
I have an 85 with a 22re and I am having a problem with the motor. Cylender 2 and 3 are not fireing, they are getting spark but 1 and 4 are the only ones turning the motor over. Any help?
Thanks ed
Thanks ed
The only other things I can think of are that the fuel injectors are clogged or there is something wrong with the valves. Im gonna check and clean up the splices more and if that doesnt work im gonna tear it down and check things out.
I pulled the wires off cylender 2 ahd put a noid light in it and started the motor and the noid light lit up and blinked as i reved the motor. So that means its the injectors right?
To tell for sure...take a long thin stick or a mechanic's stethoscope and listen to the injectors. They should be clicking when the motor is running. It's sometimes noisy down there so compare the ones that you know are working to the ones in question.
Country Hank
steve miller
10-10-2015 01:40 AM
Odin
07-15-2015 09:28 PM
