85 22re automatic totally guttless
Old 04-19-2012 | 09:15 PM
stngllhm's Avatar
does anyone know the vin breakdown to tell what gear ratio my axles are. i had been told if you had the auto you where suppose to have 4.30 gears.
Old 04-19-2012 | 09:42 PM
Vang530's Avatar
How much would you like the TCU for?
Old 04-19-2012 | 09:57 PM
stngllhm's Avatar
make an offer not sure what its worth I'm gonna do the swap this weekend
so i found my axle code its g282 so according to the chart i found i have 4.30 gears
Old 04-20-2012 | 12:39 AM
Utah4Runner86's Avatar
Originally Posted by BoredOutnJackdUp
You'd be surprised how much 31s an automatic and a tired motor would make your truck a dog.
This. That 22re doesn't make a lot of HP at it's best. It's geared to compensate for that, but an old motor and tires even slightly larger than stock will still destroy your acceleration.
The automatic doesn't help, but try regearing for your tires first.
Old 04-20-2012 | 12:40 AM
  #25
http://www.brian894x4.com/Gearratiosanddiffs.html
You should have 4.30s, if they're stock.
Old 04-20-2012 | 06:03 AM
  #26
stngllhm's Avatar
i ran 35s with a 22r and a 5speed with 4.10 i think once i get my 5speed in this with truck with 4.30 and 31s it should be good. id love to regear but i just got married and all my extra play money has evaperated so yea.
Old 04-20-2012 | 07:12 PM
  #27
ephwang's Avatar
I assume your automatic is shifting correctly, right? I only ask because, before I bought my friend's truck, he was complaining about his 85 22RE auto. When I took a ride with him, I noticed his truck wasn't shifting. He stuck it in D expecting it to shift 1-2-3 from a dead stop. But in reality the transmission was stuck in 3rd. Once I told him to "manually" shift the gears, the truck got up to speed a lot quicker. It is still slow and won't beat a 5spd, but at least we can get on a freeway onramp with a little more confidence of not being run over.
Old 04-21-2012 | 03:02 PM
  #28
stngllhm's Avatar
yea i can feel it shift threw all 4 gears it shifts out of 1st at around 25 to 30mph it shifts out of 2nd at 50 or so and out of 3rd whenever i let off the gas after that.
Old 05-01-2012 | 02:49 AM
  #29
LADave's Avatar
Just for yucks, try replacing the O2 sensor if it's gone more than 80K miles. I got a dramatic increase in pep by doing it at 107K.
Old 05-04-2012 | 11:28 PM
  #30
maco35's Avatar
Adjust your TPS.
Old 05-05-2012 | 07:22 AM
  #31
dsal_86Yota's Avatar
How many miles are on it? I got a 86 with 22re Auto and ran 35s on it and did fine. It wasnt gonna pass much on the highway but it did fine and it has 211,000 on the stock engine. When I had 31s it was getting 18-20mpg in the city/highway mix. I'd get the other engine built and put it back in.
Old 05-05-2012 | 08:48 AM
  #32
BoostedRNR's Avatar
I had an auto behind my turbo and it sucked ace off the line! You would have to power brake it if you were going to jump even the biggest gaps. I threw a 5 speed in it and it feels like a completely different truck! BTW, I run 31's and stock 4:10 gears
BeMiceElf
10-10-2015 09:40 PM
jbandt
08-03-2015 03:23 PM
Cabell
07-24-2015 12:14 PM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: 85 22re automatic totally guttless
