84 altimiter gauge ?
How does it work? do u need to adjust it at a certain number so it will work? I have one I dont know if it works? also what r the other numbers around the outside of the guage for? it seems like it moves little bit goes from about 1000 to 1300 feet? I live in kentucky And i am pretty sure I am not that high above sea level. all replies will be greatly app! thanks
You'll need to find the elevation for your location, a simple search on the web should get you there. On level ground first set the elevation, then the pitch and roll. that's about it.
It's just a simple barometer and not particularly accurate. The reading will change not only on altitude but also as the local atmospheric pressure changes with varying weather patterns.
If you really want to "calibrate" it then you need to dial it to your current elevation (just google elevation of city "X", with X being wherever you are) and do so on a day when there isn't a particularly high or low pressure system influencing the reading.
Don't expect this gauge to accurately tell you when you've gone up or down a 100' in elevation! However, if it reads 0 +/- a few hundred feet at the beach then it will read 6000' +/- a few hundred feet in Denver.
Yes, adjust it to a known elevation. I usually find with mine that I set it to the elevation signs along most of the major highways here in CA. If I set it once above 4000' when going up or set it once below 4000' going down, then it is fairly accurate. And with a big storm moving it, it'll read a few hundred feet high due to the low pressure of the storm.
- http://www.4crawler.com/4x4/CheapTri...l#Introduction
ashamsuddin
17
07-22-2024 03:59 AM
kawazx636
10-06-2021 03:03 PM
