5.29 and 4.11 question..
so i have enough money saved up to get a set of 5.29's for the rear of my 85..
my concern is.. sometimes when shifting into reverse, (or a dumb passenger playin with the sticks) sometimes i notice my 4wd light is on..
if i have 529s in back and 411 up front.. it will only blow the xfer case if the hubs are locked too right?
just a question until i can get both sets in..
Correct, if front hubs are unlocked, it makes no difference if the ratios are different. To be safe, you could always remove the front drive shaft until you get both gear sets installed.
FS[SouthCent]: Toyota Trail Gear 5.29 Ring and pinion x2 NEW
YotaLogic
12
11-17-2015 06:27 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
justdifferentials
09-05-2015 06:52 PM
coffey50
07-28-2015 10:55 AM
