1st Gen 22R rebuild
1st Gen 22R rebuild
After pulling the head and finding the flat cam I looked at the block in the truck the next morning and lone and behold there was a nice scratch in the 3 cylinder. Sooo I decided to pull the motor and do a full rebuild. Here are some pics of the progress..
Block stripped
block and rotating assembly in the car ready for a full machine shop treatment
while waiting for the machine work to complete i painted all the other parts olive and flat black
finished cs-120 alternator
starter getting the same paint treatment
oil pan
The last paint work and cleaning is the head. I'm gonna start on that this week and paint it the olive color as well. My next posting will be about post machine shop work. Stay tuned!
Block stripped
oil pan
I talked to the machine shop several times throughout the machining process and decided on a .020 overbore and align hone the mains. They also skimmed the top of the block .008. Upon inspection of the crank they grinded the main and rod journals .010 under, installed ARP rod bolts, new pin bushings, and resized the big end of the rods. After that they balanced the rotating assembly. I decided to go with Lcengineering hypereutectic pistons.
finished timing cover
block fresh from the machine shop
washing the crank
out with the black and in with the olive
I'm going with ARP head bolts and main studs. One night I decided to go ahead and screw in the main studs and check this out..
So I called ARP and they would ship me a new stud for free. I got the package within the week and... well it was a stud alright... one for a Mitsubishi! So that small setback continues as I have to wait till tomorrow to call them again. I also ordered the wrong main bearings. I have the 81-82 22R since bottom bearing caps have a offset location tab not a centered one.. oops my bad.. So this is where I am till this point.
washing the crank
I do love a clean naked engine.
When I replace my 22R engine about a year and a half ago, I bought it already done; a long block rebuild (stage 2). If I had another need to do an engine replacement, I would do what your doing. I'd tear it down myself, give it to the machine shop for them to do their thing and assemble it myself.
It's been a very fun experience so far. Thankfully I've been able to take my time and do things properly (at least I hope I am) Once I get my single ARP main stud and the right bearings the assembly begins!
I beleive that. Even though I bought my eingine as a long block, it was enjoyable stipping it down of the stuff I needed to transfer over.
Suprisingly my engine (22R) was not that difficult to remove. With hindsight being 20/20, the first thing I should removed was the exhaust pipe to the exhaust manifold. Those three bolts would have held up the whole engine removal process.
It's been awhile since I updated this so here are a few more pics of the build..
pistons
arp main studs
clearance checking the crank
crank installed
pistons in
timing chain with LC adjustable cam gear
short block done
arp head studs
long block done
intake installed
oil pre-luber
on it's way in!
yaay! installed
pistons
arp main studs
crank installed
pistons in
short block done
arp head studs
long block done
intake installed
oil pre-luber
on it's way in!
yaay! installed
anniesball
07-29-2015 11:46 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
