Pre 84 Trucks 1st gen pickups
Toyota 3" lift gone wrong :(
Old 07-15-2009 | 09:49 PM
bruzryoda's Avatar
Ouch, rough countrys r just that from what have heard. from some of the locals, around here where i live. thats why i went with Skyjacker. With the taperd spring. And i have to admit for a budget lift it rides pretty nice. and so far the riding style i have, the flex is not to bad either.
Old 07-16-2009 | 10:01 AM
eggblade1's Avatar
darn, I heard rough country was a good name.
Old 07-16-2009 | 05:21 PM
slacker's Avatar
dude ... I'm sure glad your "listening" to the advice your getting !!!! whats the point of asking , if your not going to listen ?
put some weight on it .. sand bags , dumb bells .. heck a barrel full of water !!! .. what ever . you need ~ 300 LBS to "simulate" the original truck box .. then with a jack and pry bar , you should be able to "flip" the shackle , and they should be about verticle (untill they settle) .. BUT obviously , it wont last , because you can drive the truck with a barrel of water on there ! ... once you drive it , it should settle a bit more , correcting the shackle angle .
UNTILL YOU DO THIS ... YOU"LL NEVER FIX IT !!!!
Old 07-16-2009 | 05:25 PM
SpecialScottie's Avatar
x2
Old 07-16-2009 | 10:07 PM
  #25
eggblade1's Avatar
heh, yeah I know. I'm just gonna wait to get the bed. I just dont want to leave people hanging, if someone replys to my thread I want them to know im listening and tell them what im doing atm.
I posted the pic to show what the prying w/o the bed has done. I'm gonna stack some lumber on it when I can but I havent had the time to do so yet.
BUT... I was taking your advice.
Old 07-16-2009 | 10:13 PM
  #26
algranger's Avatar
Wtf never seen that one before. I'd say the springs are too short. Whats with the angle on the leafs though? It looks like the leaf pack is pointing towards the ground
Old 08-13-2009 | 11:29 AM
  #27
islandboyjt20's Avatar
i say you need about a 1 inch longer shackle that way it will push the frame up and your spring down a little bit...your truck will be about 1-2 inchs higher in the rear...try a longer shackle if it doesnt work than you can always return it...hope i helped...
Old 08-18-2009 | 06:56 PM
  #28
Crtzlow's Avatar
Is there a possibility that the springs are turned the wrong way? Like they are longer from center to one end than the other? Weight is the only thing to do to get the springs to flatten out. I got a 3" RC kit but did not get the rear springs. Everything worked out great. It was pretty rough at the start but has settled in and is tolerable. It's a 4x4, it is supposed to be stiff, it ain't a Cadillac, however mine has the emblem on the hood.
Old 08-19-2009 | 12:10 AM
  #29
yodercrawler55's Avatar
i had the same prob with the same exact lift, when you install the springs you have to bolt the rear one on first then push it back and then bolt on the front part of the spring
Old 08-19-2009 | 11:30 AM
  #30
desertcamper67's Avatar
That spring is in a bind because of the shackle angle. Don't put weight on it until you get that shackle back and relieve that bound up spring.
Old 08-19-2009 | 03:10 PM
  #31
Island_Yota's Avatar
To me it looks like the actual shackle mounts themselves have been moved towards the back of the truck, or it could be a newer frame which used longer rear springs from the factory.. or you installed them backwards.
Ive seen inverted shackles, but.. never that far, id think putting weight on it with them like that would just bind them up backwards.
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
ptb12
07-05-2015 01:49 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Toyota 3" lift gone wrong :(
