Pre 84 Trucks 1st gen pickups
Top of Piston hitting cylinder head
Old 08-09-2022 | 09:29 AM
ericklofgren's Avatar
Hi all!
First time posting here, but I have a 1982 pickup, 22R that is down to the block. I have a new cylinder head installed, and I'm rotating the crank to make sure everything looks good, it sounds like it's hitting something. So I pull the head back off, and sure enough the piston has a raised ring on the top, and that is hitting the mating surface of the cylinder head
What are my options? I've been thinking of just replacing the pistons (since everything is pulled apart to that point anyways) or can I have a machine shop machine the head to fit the pistons? Is that a thing? I'm kind of stuck.
Old 08-09-2022 | 10:06 AM
millball's Avatar
Either the new cylinder head is not the correct type, or the block has been decked excessively.
If the head is correct, The crown of the pistons might be machined, or a suitable spacer type thick head gasket used.
Do you have the old head for comparison??
The following users liked this post:
ericklofgren (08-09-2022)
Old 08-09-2022 | 11:26 AM
OK! That makes sense. I do have the old head. The combustion chamber is round and fits the piston. To clarify, the old head is a perfect circle, and the new head is just space for the valves
Old 08-09-2022 | 11:37 AM
millball's Avatar
You have got the wrong head for sure.
Is there any reason a machine shop cannot refresh your old head???
old87yota (08-09-2022)
tinigunner11
03-27-2013 11:02 AM
SHIFTER
12-09-2010 01:31 PM
machine23
08-13-2009 10:29 AM
LegendofJake
09-02-2008 02:12 PM
vmax84
12-12-2005 11:45 AM
Quick Reply: Top of Piston hitting cylinder head
