Steering Column 1983 4WD
Does any know if a 2WD tilt steering column can be used in a 4WD application?
If it does not fit, or can not be used does any one have a 4WD Tilt steering column for a 1983 4WD Truck?
Thanks
Thanks
You can find used steering columns on https://www.car-part.com/
Just make sure you specify the model as "1983 Toyota Truck (except T100 & Tundra)".
I tried the search there both ways, for 2WD (4x2) and for 4x4 and different listing came up for each, so I would assume the 2WD column would not fit a 4x4 model.
