Need a new line for the slave clutch cylinder
I purchased a new slave clutch cylinder and screwed up while installing it, cross-threading the line connection. No way I can clean that up.
Is there any place I can get a replacement for this piece? I've attached a pic. I don't know anything about flaring brake lines so would need something either plug and play or a workaround from the auto parts store, if possible. Any help gratefully taken...thanks!
Buy the correct size line both in length and in the nuts at most auto parts stores
Then bend it to fit as needed being careful not to kink it.
Maybe time you learn how to flare things ??
Regarding on learning how to flare, I think you're right! (The clerk also showed me a tool they rent for doing it.)
Alchain
02-09-2016 10:39 PM
vinman33
11-05-2015 12:53 AM
shisha1999
10-21-2015 03:14 PM
