My new Rig....!
My new Rig....!
http://www.pbase.com/kncrsr5r/1982_toyota_4x4
1982 4x4 22R
.020 over
Comp Cam
LCE Adjustable timing set
Desmogged
So far its great. Need to change throwout bearing and pilot bearing. I got it with and additional front and rear axle and suspension. Additional Head, and carb.
I need to remove the winch and re-mount to a stronger platform. Not Sure what the design of this will be yet.
Still trying to determine what it will have to have. I know I need the capabilities of a full use bed of some sort that will allow a topper for my dogs. The original bed is ok...but has plywood covering the majority of it. So the bed may be crap???
Post up some ideas...thoughts...general encouragement.
1982 4x4 22R
.020 over
Comp Cam
Desmogged
looks like a nice rig ... maybe a saver ! depending on how long your going to keep it for , you might look at http://www.toyotafiberglass.com fo a new bed .. you can use them as you would a stock bed .
Yep ... not in everyones budget ..
but just for referance on the big rock .. check this out .
http://s76.photobucket.com/albums/j2...edgehammer.flv
"amaturish" and obviously un-retouched .. easly tougher then steel
aa1911
19
12-14-2011 04:54 PM
